Description: Im new in PollEx and im trying to understand it, but when I try to simulate the "network analysis" it says "Spice run error".
The spice that i have are:
.SUBCKT irfz44n 1 2 3
- Model Generated by MODPEX *
Copyright(c) Symmetry Design Systems
- All Rights Reserved *
- UNPUBLISHED LICENSED SOFTWARE *
- Contains Proprietary Information *
- Which is The Property of *
- SYMMETRY OR ITS LICENSORS *
*Commercial Use or Resale Restricted *
- by Symmetry License Agreement *
- Model generated on Apr 24, 96
- Model format: SPICE3
- Symmetry POWER MOS Model (Version 1.0)
- External Node Designations
- Node 1 -> Drain
- Node 2 -> Gate
- Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u - Default values used in MM:
- The voltage-dependent capacitances are
- not included. Other default values are:
- RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=3.56214 LAMBDA=0 KP=39.3974
+CGSO=1.25255e-05 CGDO=2.2826e-07
RS 8 3 0.0133305
D1 3 1 MD
.MODEL MD D IS=9.64635e-13 RS=0.00967689 N=1.01377 BV=55
+IBV=0.00025 EG=1.08658 XTI=2.9994 TT=1e-07
+CJO=1.39353e-09 VJ=0.5 M=0.42532 FC=0.5
RDS 3 1 2.2e+06
RD 9 1 0.0001
RG 2 7 2.20235
D2 4 5 MD1 - Default values used in MD1:
- RS=0 EG=1.11 XTI=3.0 TT=0
- BV=infinite IBV=1mA
.MODEL MD1 D IS=1e-32 N=50
+CJO=1.52875e-09 VJ=0.5 M=0.584414 FC=1e-08
D3 0 5 MD2 - Default values used in MD2:
- EG=1.11 XTI=3.0 TT=0 CJO=0
.MODEL MD2 D IS=1e-10 N=0.408752 RS=3e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 2.06741e-09
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3 - Default values used in MD3:
- RS=0 BV=infinite IBV=1mA
.MODEL MD3 D IS=1e-10 N=0.408752
For the MOSFET that is:
