How to know a CFD Analysis solution get converged or not?
Sivaprakash_V
Sivaprakash_V Altair Community Member
Hi ,
I have been conducting a CFD analysis of the air blower model using Simlab and the Acusolve solver. To estimate the first layer height of the boundary layer, I utilized the HM CFD Y+ calculator. Using this first layer height, I generated volume meshes with 5, 8, and 12 boundary layers, employing maximum mesh sizes of 2mm and 3mm, respectively. This resulted in six different meshed files.
For the solution, I used the Spalart-Allmaras turbulence model and selected steady-state as the solution type.
Initially, I performed the analysis using the 3mm mesh with three different boundary layers, the solution solved for 100 time steps (which is the default for steady-state problems). Subsequently, I analyzed the 2mm mesh model with 5 and 8 boundary layers, with the 12 boundary layer model currently running. Notably, the 2mm mesh with 5 boundary layers solved with 50 time steps, while the 8 boundary layer model reached 100 time steps.
The primary output of interest in this analysis is the volume flow rate. I observed that the volume flow rate varied significantly across the different mesh sizes and boundary layer configurations. How can I determine the final, most accurate output based on this analysis?
Additionally, how can I verify whether the solution has converged?
In general, what does "convergence" mean in the CFD simulations?
For reference, I have attached images of the residuals plot and the mass flux plot. Is it correct to assume the solution has converged if the residuals are within 1e-4, or is there another method to assess solution convergence?
Thanks & Regards,
Sivaprakash V.
Best Answers
  • Jagan
    Jagan Altair Community Member
    Answer ✓
    Hi Sivaprakash,
    Convergence and accuracy are two different aspects of a CFD solution. A converged solution can be obtained with a coarser mesh, but it may not accurately represent the real physics due to higher discretization errors. Refining the mesh helps minimize these errors and improves accuracy, which I believe is what you are doing.
    To determine whether your CFD solution for a given mesh has converged, please refer to this https://help.altair.com/hwcfdsolvers/acusolve/topics/acusolve/training_manual/acusolve_convergence_criteria_r.htm and check if your residuals and solution ratios are within acceptable limits.
    You can further reduce the convergence tolerance (e.g. set it to 0.0001) if your interested variables (flow rate, pressure) are not stabilizing as expected after a given number of iterations. However make sure to keep the convergence tolerance same for all the 6 mesh cases.
    I believe you have attached the convergence data for only one case, is that correct?
  • acupro
    acupro
    Answer ✓
    Here is another discussion similar to that from the Help system Jagan posted earlier.
    https://community.altair.com/discussion/41587/how-does-one-judge-the-convergence-of-an-acusolve-cfd-solution?utm_source=community-search&utm_medium=organic-search&utm_term=converge+acusolve
  • Jagan
    If you're simulating the tutorial model, the SA turbulence model with standard wall functions should provide a sufficient solution without the need to resolve the boundary layer down to a Y+ value of 1. That said, refining the boundary layer further can improve accuracy, especially if your focus is on wall shear stress at the impeller.
    As you perform grid refinement study, does the percentage change in the variable (volume flow rate, in your case) progressively decrease?
    For example - if you make a mesh change and the solution of interest changes by 15% - maybe the previous mesh wasn't refined enough. Further if you refine the mesh and the variable of interest changes by 10% or lesser then you are going in the right direction.
  • Sivaprakash_V
    Hi jagan,
    I am mainly focused on volume flow rate of the air blower.
    So performed the mesh independence study.
    Then based on the above mentioned residuals and mass flow at inlet & outlet, how to determine the solution is converged or not?
    I attached the values for your reference.
    Based on the above results how I conclude my final output?
    Thanks & Regards,
    Sivaprakash V.
  • Jagan
    Answer ✓
    Hi Sivaprakash,
  • Sivaprakash_V
    Yes, I attached the convergence data for one of the cases.
    Are you review the table which I shared. It contains mesh size, BL and value of volume flow rate.
    Sure, I will go through the convergence criteria.
    Now based on the tables, can I confirm the final volume flow rate as 2.8 or 2.95.?
    Thanks & Regards,
    Siva prakash V.
  • Jagan
    Have the residual and solution ratios of both solutions, where the flow rates are 2.8 and 2.93 m³/min, converged below the same limits (i.e. 1e-4)?
    And is the flow rate value constant at 2.8 or 2.93 as the iteration progresses in both cases?
  • Sivaprakash_V
    Yes, for both cases the residual and solution ratio with 1e-4.
    Actuall, 2.8,2.8 and 2.93 are the volume flow rate values at 5,8 and 12 BL at two different Mesh sizes.
    At the size of 2 and 3 mm, the value of volume flow is 2.8meter cube per minute for 5 and 8 layers respectively.
    But for 12 BL, the values of volume flow rate got increased which reached 2.93 and 2.94 respectively.
    Thanks & Regards,
    Sivaprakash.
  • Jagan
    Are the Y+ values, first layer height, and growth rate the same for the 5-8 BL and 12 BL cases?
    Also is it possible for you to share a picture of the respective residual and solution ratios?
  • Sivaprakash_V
    Hi Jagan,
    Yes, the Y+ values, first layer height, and growth rate the same for the 5-8 BL and 12 BL cases.
    I will share the screenshots of the residuals and solution graph for the cases which I performed.
    Thanks & Regards,
    sivaprakash V.
  • acupro
    acupro
    Answer ✓
  • Sivaprakash_V
    Hi Jagan,
    This PDF contains the residual, solution & Mass flux Plot for my analysis.
    Thanks & Regards,
    Sivaprakash V.
