I am doing constant radius analysis but getting this error. How to resolve this ? I am using Hyperworks 17.0
Hi Adit Agarwal
Use windows folder options > unhide known extensions, to make sure the file is named altair_lic.dat and not altair_lic.dat.dat,
You need to confirm if the Ethernet address in the license file is the correct one and matches the one in your machine.
When you open the license file in a text editor you will see an Ethernet address there in a line that says 'ETHERNET =
The Ethernet ID is the ID of your machine which is exactly 12 hexadecimal numbers. For example D4WRF478F398
Run ipconfig/all in command window and check for physical address under Ethernet adapter local area connection or Ethernet adapter Ethernet
The listed physical address under Ethernet adapter local area connection or Ethernet adapter Ethernet should be used to generate the license file
Check whether the Host-id of your system matches with the generated license file.
if the Host-id does not match the one in the license file, please request for the license file again with the correct Ethernet ID.
