Help needed, I am new to HW. I was making a Pena Mig Line connector weld on HM and face this issue. Kindly help. I need a 3mm weld near the cylinders. Thank you.
Hi Adisen Can you please try to remove all old connectors un-realize and delete (or in connector browser select delete + FE) I did that and created a new based on the outer line in the plate
//Johan
Hi Adisen I did try on your model in Hypermesh 2024.1 (which version did you use?) Removed all connectors and created a new on the outer line, tested with two pitches.
Kind regards //johan
Hii Johan. I used v2023. If possible can you check the connectors i used and tell me what I did wrong. Thank you Regards Adi
