Hello~All
Help me…ㅠㅠ
I conducted the analysis using Nastran SOL103.
I am having trouble troubleshooting.
I have attached the relevant data.
As far as I understand, you are defining an RBE reference point from nodes which have only solid elements (solid element do not have rotational stiffness associated). So you need to correct your RBE3 cards and use only 123 instead of 123456
Hello
You should reach out to Nastran support regarding any Nastran solver error.
Thanks
you should provide the .f06 file or part of it when FATAL occurs
0S O R T E D B U L K D A T A E C H OENTRYCOUNT . 1 .. 2 .. 3 .. 4 .. 5 .. 6 .. 7 .. 8 .. 9 .. 10 .ENDDATA TOTAL COUNT= 1753606 INPUT BULK DATA ENTRY COUNT = 1753611 1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38976 MODE SHAPE0M O D E L S U M M A R Y BULK = 0 ENTRY NAME NUMBER OF ENTRIES ---------- ----------------- CHEXA 2811 CQUAD4 820839 CTRIA3 17390 EIGRL 1 GRID 868571 MAT1 6 PSHELL 5 PSOLID 1 RBE2 566 RBE3 20249
*** USER WARNING MESSAGE 285 (DML) FATAL ERRORS WERE FOUND WHILE READING THIS BEGIN SECTION MODEL SUMMARY DOES NOT INCLUDE COUNT OF FATAL ENTITIES ^^^^^^ >>> IFP OPERATIONS COMPLETE <<< ^^^*** USER INFORMATION MESSAGE 22964 (rmrgdrot_impl) One or more RBE3 elements have been detected for which the dependent GRID connects to solid elements only but dof 456 have been specified as part of REFC. In some cases, this may cause inefficient processing. Up to 50 pairs of RBE3 and REFG with this occurring are listed below. User Action: If this is intentional, ignore this message, otherwise, you can set MDLPRM,RMRBE3RT,1 to automatically remove dof 456 from the REFC on these RBE3s. 1855967 48743238 1855968 48743239 1855969 48743240 1855970 48743241 1855972 48743242 1855973 48743243 1855974 48743244 1855975 48743245 1855977 48743247 1855978 48743248 1855979 48743249 1855980 48743250 1855981 48743253 1855982 48743254 1855983 48743255 1855984 48743256 1855986 48743257 1855987 48743258 1855988 48743259 1855989 48743260 1855991 48743262 1855992 48743263 1855993 48743264 1855994 48743265 1855995 48743268 1855996 48743269 1855997 48743270 1855998 48743271 1856000 48743272 1856001 48743273 1856002 48743274 1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38977 MODE SHAPE00
1856003 48743275 1856005 48743277 1856006 48743278 1856007 48743279 1856008 48743280 1856009 48743283 1856010 48743284 1856011 48743285 1856012 48743286 1858002 48743287 1858003 48743288 1858005 48743289 1858036 48743290 1858039 48743292 1858041 48743293 1859573 48743294 1859574 48743295 1859575 48743298 1859576 48743299
^^^*** USER FATAL MESSAGE 9002 (SUBDMAP IFPS) ERROR(S) ENCOUNTERED IN THE MAIN BULK DATA SECTION SEE MESSAGES ABOVE. ERROR ENCOUNTERED IN MODULE IFP, ^^^1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38978 MODE SHAPE00
*** USER INFORMATION MESSAGE 4425 (PRTPRN) ONE OR MORE FATAL ERRORS HAVE OCCURRED. THERE MAY BE MORE ERROR MESSAGES IN THE PRECEDING OUTPUT 1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38979 MODE SHAPE0
0SEID = SUPERELEMENT ID. PEID = PRIMARY SUPERELEMENT ID OF IMAGE SUPERELEMENT. PROJ = PROJECT ID NUMBER. VERS = VERSION ID. APRCH = BLANK FOR STRUCTURAL ANALYSIS. HEAT FOR HEAT TRANSFER ANALYSIS. SEMG = STIFFNESS AND MASS MATRIX GENERATION STEP. SEMR = MASS MATRIX REDUCTION STEP (INCLUDES EIGENVALUE SOLUTION FOR MODES). SEKR = STIFFNESS MATRIX REDUCTION STEP. SELG = LOAD MATRIX GENERATION STEP. SELR = LOAD MATRIX REDUCTION STEP. MODES = T (TRUE) IF NORMAL MODES OR BUCKLING MODES CALCULATED. DYNRED = T (TRUE) MEANS GENERALIZED DYNAMIC AND/OR COMPONENT MODE REDUCTION PERFORMED. SOLLIN = T (TRUE) IF LINEAR SOLUTION EXISTS IN DATABASE. PVALID = P-DISTRIBUTION ID OF P-VALUE FOR P-ELEMENTS LOOPID = THE LAST LOOPID VALUE USED IN THE NONLINEAR ANALYSIS. USEFUL FOR RESTARTS. SOLNL = T (TRUE) IF NONLINEAR SOLUTION EXISTS IN DATABASE. DESIGN CYCLE = THE LAST DESIGN CYCLE (ONLY VALID IN OPTIMIZATION). SENSITIVITY = SENSITIVITY MATRIX GENERATION FLAG.
No PARAM values were set in the Control File.
1 * * * END OF JOB * * *
No Symbolic Replacement variables or values were specified.
Thank you.
But MDLPRM, RMRBE3RT, 1 to automatically remove dof 456 from the REFC on these RBE3s. How do I do this??
