🎉Community Raffle - Win $25
Join and Win
Using Your Designed, Custom Sections in S-FRAME.
User: "Alejandro_López_Av"
Updated by AltairLiz
S-FRAME stores and displays different steel section databases, letting the user decide which sections are more fitting to represent and try different conditions. In common practice, the user tends to use these default databases, however, some projects and models require using sections with specific properties, outside of the common databases. This can be achieved through S-CALC, a powerful section designer tool from the S-FRAME suite, and then by merging the sections to S-FRAME, the user can analyze and even code-check their structure, giving more freedom to manage their projects.
We present a video that shows the workflow for this process, including the valid shapes, the file type, and how to assign and select these custom databases.
Comments
No comments on this post.
