Rainflow Counting Algorithm - Create Simple 3D Plot
Overview: This OML script shows how to create a 3D histogram from results from the rainflow OML command. These are the steps it takes:
  1. Create signal to analyze
  2. Evaluate rainflow counting algorithm
  3. Create 3D histogram from means & ranges
  4. Format histogram to show cycle count for means & ranges
Prerequisite: Install Altair Compose 2022.1 or later / Download attached script.
Usage/Installation Instructions: Download the attached OML file. Open in Compose and run it to inspect the resulting plot.
Post-Requisite: Substitute the signal definition segment of the script with your own data (can be imported from external sources) if desired.
Release Version: This OML script was created in Compose 2024.1, but should work in earlier version up to Compose 2022.1.
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
