Hi all!
In Simlab, I have made a flow simulation with electrical effects. The output includes the current density. However, I am interested in the total current through a surface. In theory, the current is the integral of the current density over the surface elements of a surface. Similar integration must have already been built into Simlab, to calculate heat flux, for example. So I assume there is a way to integrate current density as well, but I have not found any.
Is there a way to calculate the total current through a surface? If User-defined response is the right function, how to write a code for integration which works in Simlab? Or should I use an alternative solution?
