Hi! I am currently looking to perform a finite element analysis for a 3D block with dimensions 2 x 0.4 x 0.05 for which i am applying constraints on one face of the block which has cross section 0.4 x 0.05 where i have meshed this using '0.1' sized meshing hence 8 nodes (4 on the upper edge and 4 on down edge) are under fixed constraints. Opposite to this face the other edge has force on its four nodes in downward direction of 10000 magnitude. I applied loadstep further and all material and property and clicked on analyze and optistruct is also generating result file but i am unable to see proper results as in not able to visualize deformation.
I need help with finally being able to visualize this deformation properly in optistruct and also record the coordinates of nodes of block before and after deformation and also record which nodes experienced force and fixed constraints. It would be helpful if i am directed to some sort of tutorial for this or please help me visualize the results properly.
