Dear All,
I have searched for "fmtsearch" on this website and got " no result found"…
Is it supported by ALtair?
In an existing SAS program I use the option fmtsearch(libname) to say in which library to search for existing formats.
When I run this in Altair analytics workbench I get neither an error neither a message telling it is ok
It looks it does not work because when I open a dataset whose formats are defined in this specific library, I get the following error message (which I did not get when using SAS) :
data regselrest;
ERROR: Format $FBLESSE was not found or could not be loaded
4234 set svg.regselrest;
4235 run;
NOTE: DATA step was not executed because of errors detected
NOTE: The data step took :
real time : 0.023
cpu time : 0.000
Thank you in advance for your help
