Overview: This Script can reduce labor when you have a large number of components and need to assign the same Property. Logic that uses 2D shell thickness information from the Component name to create a corresponding Property and assign it to the Component.
Step1)
There is a "t" in the Component name. This is the shell thickness information for the Component, and there are multiple Components that require the same thickness.
Step2)
This is the result of automation.
For example, three Components that require a thickness of 10 will see a Property with that thickness assigned after creation.
Release Version:
