Hello expert
I used PSIM and TI LAUNCHXL-F28069M & BOOSTXL-DRV8301 to control motor.
When I use J1-J4 (PWM 1 -3) to connect F28069M and DRV8301, everything is OK.
Now I need to use J5-J8 (PWM 4-6) to connect F28069M and DRV8301.
My PSIM 3-ph PWM block set as below.(PWM Source: 9-phase PWM 123→ PWN 456).
Is this setting correct or I need to set another place ?
thank you
