I am using hyper works motion view student version to run my case study. My case study involves series of point mass bodies connected with each other through springs and having joints to allow relative motion between point bodies. The system represents a cantilever beam in which I am applying a load at the tip.
I am able to run a static simulation (see figure for initial and final position) but I'm not sure if there is an easy way to get nodal positions of all points after the analysis which can be saved as a .csv file.
