I need the formula of Avg. within centroid distance in RapidMiner,
I need some references for the formula
thanks
Hi @Ebtihal
Just to clarify, do you need to know how to apply this formula, or understand the formula it is using?
Thanks,
Roland
yes, I know the formula for each cluster is:
for all clusters is:
so, I need justification of those formulas, also some references for them
This is a very commonly used formula, so I would recommend searching through academic sources if you think you need a reference. For example, I found this book referencing the measure:
https://www.sciencedirect.com/topics/computer-science/cluster-centroid
Hope this helps,
it helps,
