I am working on a model that utilizes an IGBT component where the IGBT's temperature is set at 125 °C, while the antiparallel diode's temperature is set at 75 °C .
In the version I am currently using (PSIM 2022.2), I believe there is no equivalent component that allows me to impose separate temperatures for the IGBT and the diode.
I attempted to use the component shown in the image below, but it appears I can only impose a single temperature for the entire device.
My objective is to use an IGBT with an antiparallel diode and set different, constant temperatures for the IGBT and the diode throughout the simulation.
Could you please advise if this is possible with the current version of PSIM or suggest an alternative method to achieve this?
