Good morning,
I am simulating a rectangular beam with a length of 500 mm and a width of 100 mm, subjected to a tensile force of 500 N in the longitudinal direction. The beam is fixed at the opposite end, with a boundary condition of zero displacement applied to all grids on that side.
The model is a composite laminate composed of 8 plies, each 1 mm thick, with the following symmetric layup sequence: 0/-45/45/90/90/45/-45/0. My issue is that when I calculate the displacement in the X direction analytically, the values are smaller than the results obtained from my FEM model.
I suspect this discrepancy could be due to one of the following reasons:
a) I am using the elastic modulus E1 in the fiber direction for the analytical calculation. Could it be that OptiStruct uses an equivalent elastic modulus, which is a weighted average of the laminate's plies?
b) My mesh consists of CQUAD elements with a side length of 20 mm. However, since this is a simple loading case, I don't believe the large mesh size significantly affects the accuracy of the results. Am I wrong about this?
c) It could be due to some parameter related to the nonlinear analysis, but I am not exactly sure how or why.
