Hello, I'm trying to follow your YT tutorial on getting started with F28379D. However, I cannot simulate an example that you have provided. Please help!
As I can see from the attached image, 1-ph PWM F2837x and DSP clock are disabled. So, you are getting the error. Enable the 1-ph PWM block. For enabling the block, use ""CTRL+E".
(or)
Select the 1-ph PWM and DSP clock blocks, enable them (Please see image)
In PSIM, these schematics are available: PSIM»»File»»Open Examples»»Code Generation»»F2837x Target»»1-ph PWM.
Thank you,
Vishwanatha Siddhartha
May I know what version of PSIM and license configuration you have?
When a license lacks access to the Code Generation functionality in a software suite (like simulation or modeling tools), the corresponding elements or features related to code generation typically appear as disabled or grayed out in the user interface.
Hi, thanks for your reply. I'm using the student version. Apparently I cannot use the code generation function in this version.
