Altair RISE
Nominate Yourself Now!
How do I solve this problem that AcuSolve won't use my mesh?
User: "Tom_b29"
Altair Community Member
I am currently trying to simulate air flow through an accumulator and I set up where the air flow is simply entering one side and exiting the other. I used essentially the default CFD Mesh, only inputting the element sizes. I also used the whole body as a fluid body(not sure if it makes sense to do that). However when I went to solve the flow, I get the message "AcuSolve export is supported only for volume mesh bodies." I attached it in the photo, what does it mean and how can I get past it?
1 - 2 of 21
    User: "GTT Johan"
    Hi Tom
    Are you using Simlab?
    Looks like you have applied your conditions on either CAD part, or that the part is not 3d meshed!
    //Johan
    User: "Tom_b29"
    OP
    Sorry I forgot to put that I resolved the issue, I did not add a region for the fluid region so there was nothing to create a mesh for.
