<?xml version="1.0" encoding="UTF-8"?><process version="10.1.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.1.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="10.1.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="34"> <parameter key="generator_type" value="attribute functions"/> <parameter key="number_of_examples" value="1"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"> <parameter key="data" value=""Apr 24, 2022-Apr 30, 2022+Delay,Apr 24, 2022-Apr 30, 2022+Early,May 16, 2022-May 30, 2022+Delay,Jan 01, 2022-Jan 30, 2022+Early,Jun 26, 2022-Jun 30, 2022+NA""/> </list> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="set_macro" compatibility="10.1.002" expanded="true" height="82" name="Set Macro" width="90" x="380" y="34"> <parameter key="macro" value="field"/> <parameter key="value" value="Delay"/> </operator> <operator activated="true" class="replace" compatibility="10.1.002" expanded="true" height="82" name="Replace" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="([^+^,]+,)+[^+^,]+\+(?!%{field})[^,]+,?|(\+%{field},(?!.*\+%{field}))|\+%{field}"/> <parameter key="replace_by" value=""/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
