Rapidminer Local Repository
sundus_yousuf
New Altair Community Member
Hello everyone! Local repository is not showing after I install rapidminer, that means I cannot import any file.. please I need your help
Best Answer
Hi!
Can you upload a screenshot from your Repository panel?
You can always create new local repositories using the button marked here. As you can see, I have a bunch. The Local Repository should be created automatically.
Do you see the Repository panel? If not, select View / Restore Default View.
Balázs-1
Hi!
Balázs-1 -
Thank you for your response. I've followed the guide and it works. I had to disable my windows defender aswell while trying to create one. Thank you so much. I appreciate1
