<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.9.002" expanded="true" height="68" name="Retrieve Houston Data cleaned" width="90" x="112" y="34"> <parameter key="repository_entry" value="//Training Resources/Data/Hourly Weather/Houston Data cleaned"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.9.002" expanded="true" height="82" name="week" width="90" x="246" y="34"> <parameter key="attribute_name" value="datetime"/> <parameter key="new_name" value="Week"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.9.002" expanded="true" height="82" name="month" width="90" x="380" y="34"> <parameter key="attribute_name" value="datetime"/> <parameter key="new_name" value="DayOfWeek"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.9.002" expanded="true" height="82" name="Date to Nominal" width="90" x="45" y="136"> <parameter key="attribute_name" value="Week"/> <parameter key="date_format" value="WW"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.9.002" expanded="true" height="82" name="Date to Nominal (2)" width="90" x="179" y="187"> <parameter key="attribute_name" value="DayOfWeek"/> <parameter key="date_format" value="E"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="aggregate" compatibility="9.9.002" expanded="true" height="82" name="Aggregate" width="90" x="313" y="187"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="Temperature / Fahrenheit" value="average"/> </list> <parameter key="group_by_attributes" value="DayOfWeek|Week"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.9.002" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="187"> <list key="function_descriptions"> <parameter key="average(Temperature / Fahrenheit)" value="round([average(Temperature / Fahrenheit)],0)"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="open_file" compatibility="9.9.002" expanded="true" height="68" name="Open File" width="90" x="313" y="340"> <parameter key="resource_type" value="file"/> <parameter key="filename" value="C:/Users/MarcoBarradas/OneDrive - RapidMiner/Desktop/heatmap.json"/> </operator> <operator activated="true" class="animated_plots:plotHtml5" compatibility="9.9.000" expanded="true" height="82" name="Plot Data" width="90" x="581" y="238"> <parameter key="width" value="800"/> <parameter key="height" value="600"/> </operator> <connect from_op="Retrieve Houston Data cleaned" from_port="output" to_op="week" to_port="example set input"/> <connect from_op="week" from_port="example set output" to_op="month" to_port="example set input"/> <connect from_op="month" from_port="example set output" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_op="Date to Nominal (2)" to_port="example set input"/> <connect from_op="Date to Nominal (2)" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Plot Data" to_port="example set"/> <connect from_op="Open File" from_port="file" to_op="Plot Data" to_port="chart configuration"/> <connect from_op="Plot Data" from_port="img" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
