Given a database table how to use macros and loop to change the multiple "where" values of SELECT
User: "Somnath_Das"
New Altair Community Member
Updated by Jocelyn
Given a database table how do I use macros to change the multiple "where" values of a select query using rapidminer? I have created a sample process but there the WHERE clause is having a single condition.. I want to check for multiple conditions.
For example if I want to check like ACCOUNT_NO & CUSTOMER_ID how do I use macros and loops so a subprocess will run the following statement?
Select * from Table where account_no=suppliedValue_1 and customer_id=suppliedValue_2
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve card_fraud_txns_customer" width="90" x="45" y="34">
        <parameter key="repository_entry" value="../data/card/card_fraud_txns_customer"/>
      <operator activated="true" class="concurrency:loop_values" compatibility="9.9.000" expanded="true" height="82" name="Loop Values" width="90" x="179" y="34">
        <parameter key="attribute" value="CUST_CARD_ID"/>
        <parameter key="iteration_macro" value="loop_value"/>
        <parameter key="reuse_results" value="false"/>
        <parameter key="enable_parallel_execution" value="true"/>
          <operator activated="true" class="jdbc_connectors:read_database" compatibility="9.9.000" expanded="true" height="82" name="Read Database" width="90" x="179" y="34">
            <parameter key="define_connection" value="repository"/>
            <parameter key="connection_entry" value="/Connections/ML_UAT_DB"/>
            <parameter key="database_system" value="MySQL"/>
            <parameter key="define_query" value="query"/>
            <parameter key="query" value="select * from card_fraud_all where CUST_CARD_ID = ?"/>
            <parameter key="use_default_schema" value="true"/>
            <parameter key="prepare_statement" value="true"/>
            <enumeration key="parameters">
              <parameter key="parameter" value="VARCHAR.%{loop_value}"/>
            </enumeration>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          <connect from_op="Read Database" from_port="output" to_port="output 1"/>
          <portSpacing port="sink_output 1" spacing="0"/>
          <portSpacing port="sink_output 2" spacing="0"/>
        </process>
      <operator activated="true" class="append" compatibility="9.9.000" expanded="true" height="82" name="Append (2)" width="90" x="313" y="34">
        <parameter key="merge_type" value="all"/>
      <connect from_op="Retrieve card_fraud_txns_customer" from_port="output" to_op="Loop Values" to_port="input 1"/>
      <connect from_op="Loop Values" from_port="output 1" to_op="Append (2)" to_port="example set 1"/>
      <connect from_op="Append (2)" from_port="merged set" to_port="result 1"/>
      <background height="232" location="//Samples/Tutorials/Basics/01/tutorial1" width="1502" x="26" y="47"/>
    </process>
</process>
1 - 1 of 11
    User: "kayman"
    Accepted Answer
    Same logic, but use 'generate macro' instead of set macro. Your logic then defines the value assigned to the macros.
