<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve card_fraud_txns" width="90" x="45" y="34">
<parameter key="repository_entry" value="../data/card/card_fraud_txns"/>
<operator activated="true" class="extract_macro" compatibility="9.9.000" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="34">
<parameter key="macro" value="acct"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="statistics" value="average"/>
<parameter key="attribute_name" value="DR_ACCOUNT_ID"/>
<parameter key="example_index" value="1"/>
<list key="additional_macros"/>
<operator activated="true" class="jdbc_connectors:read_database" compatibility="9.9.000" expanded="true" height="82" name="Read Database (2)" width="90" x="179" y="136">
<parameter key="define_connection" value="repository"/>
<parameter key="connection_entry" value="/Connections/ML_UAT_DB"/>
<parameter key="database_system" value="MySQL"/>
<parameter key="define_query" value="query"/>
<parameter key="query" value="select * from cust_account where 'hostAcctId' in %{acct}"/>
<parameter key="use_default_schema" value="true"/>
<parameter key="prepare_statement" value="false"/>
<enumeration key="parameters"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<connect from_op="Retrieve card_fraud_txns" from_port="output" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Read Database (2)" from_port="output" to_port="result 1"/>
<background height="232" location="//Samples/Tutorials/Basics/01/tutorial1" width="1502" x="26" y="47"/>
</process>
</process>
