Read Excel Table with 300+ URLs and get Page Informations
New Altair Community Member
Updated by Jocelyn
I would like to get Informations such as the Response Code, Response Message, Content Type etc. of the URLs in my Excel Table. I used - Read Excel -> Store -> Handle Exception (Get Pages) -> Store - as my Process Chain. For some reason I only get the URL as my Result instead of all the Information I want. Hopefully someone can help out.
This is the Code:
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.9.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="9.9.000" expanded="true" height="68" name="Read Excel" width="90" x="112" y="136">
<parameter key="excel_file" value="/Users/XXX/datamining/excel/Leuphana.xlsx"/>
<parameter key="sheet_selection" value="sheet number"/>
<parameter key="sheet_number" value="1"/>
<parameter key="imported_cell_range" value="A1"/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="date_format" value=""/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="German (Germany)"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<parameter key="0" value="Links.true.file_path.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="false"/>
<operator activated="true" class="store" compatibility="9.9.000" expanded="true" height="68" name="Store" width="90" x="246" y="136">
<parameter key="repository_entry" value="../data/Leuphana_Links"/>
<operator activated="true" class="handle_exception" compatibility="9.9.000" expanded="true" height="82" name="Handle Exception" width="90" x="380" y="136">
<parameter key="add_details_to_log" value="false"/>
<operator activated="true" class="web:retrieve_webpages" compatibility="9.7.000" expanded="true" height="68" name="Get Pages" width="90" x="179" y="34">
<parameter key="link_attribute" value="Links"/>
<parameter key="page_attribute" value="Inhalt"/>
<parameter key="random_user_agent" value="true"/>
<parameter key="connection_timeout" value="10000"/>
<parameter key="read_timeout" value="10000"/>
<parameter key="follow_redirects" value="true"/>
<parameter key="accept_cookies" value="all"/>
<parameter key="cookie_scope" value="thread"/>
<parameter key="request_method" value="POST"/>
<parameter key="delay" value="none"/>
<parameter key="delay_amount" value="1000"/>
<parameter key="min_delay_amount" value="0"/>
<parameter key="max_delay_amount" value="1000"/>
<connect from_port="in 1" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<connect from_port="in 1" to_port="out 1"/>
</process>
<operator activated="true" class="store" compatibility="9.9.000" expanded="true" height="68" name="Store (2)" width="90" x="514" y="136">
<parameter key="repository_entry" value="../data/Leuphana_Result"/>
<connect from_op="Read Excel" from_port="output" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_op="Handle Exception" to_port="in 1"/>
<connect from_op="Handle Exception" from_port="out 1" to_op="Store (2)" to_port="input"/>
</process>
</process> Find more posts tagged with
1 - 6 of
61
Hi @Naveen_Vimalan,
The process you posted is broken. Are you able to attach the excel file or process file (.rmp)? I have built some web scraping and web mining process to get reviews from indeed, yelp, G2, etc.. Attached is the one used for storing the HTML web pages as the first step.
HTH!
YY
HTH!
YY
Hi @yyhuang,
I attached the excel and .rmp file down below. I also added a picture of the results I want to achieve with the 300+ URLs instead of only 4 results as shown in the screenshot.
Best Regards,
Naveen
Best Regards,
Naveen
Are you able to import the process I shared? @Naveen_Vimalan
Generally, get page works better than "get pages".
Hi @Naveen_Vimalan,
I used your excel as input for URL links and got 325 results and 8 errors (see attached screenshot for the error msg). The errors mostly come from the bad URL link that contains regex (why regex?)
Process with loop and Get Page attached for your reference.
Cheers,
YY
Cheers,
YY
1 - 1 of
11
Hi @Naveen_Vimalan,
Cheers,
YY
Cheers,
YY
Please read this interesting thread about the Web Page Operator
network connection with Get Pages - operator — RapidMiner Community
I attached a simple process to handle with, please try with it,
Best
