I thought this was a problem of my model, but it doesn't work in the Tutorial either. Error message is "Wrong connection. Your connection is producing the wrong type of data. Try changing the starting point of the connection."
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve Deals" origin="GENERATED_TUTORIAL" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Samples/data/Deals"/>
<operator activated="true" class="h2o:logistic_regression" compatibility="7.2.000" expanded="true" height="124" name="Logistic Regression" origin="GENERATED_TUTORIAL" width="90" x="179" y="34">
<parameter key="solver" value="AUTO"/>
<parameter key="reproducible" value="false"/>
<parameter key="maximum_number_of_threads" value="4"/>
<parameter key="use_regularization" value="false"/>
<parameter key="lambda_search" value="false"/>
<parameter key="number_of_lambdas" value="0"/>
<parameter key="lambda_min_ratio" value="0.0"/>
<parameter key="early_stopping" value="true"/>
<parameter key="stopping_rounds" value="3"/>
<parameter key="stopping_tolerance" value="0.001"/>
<parameter key="standardize" value="true"/>
<parameter key="non-negative_coefficients" value="false"/>
<parameter key="add_intercept" value="true"/>
<parameter key="compute_p-values" value="true"/>
<parameter key="remove_collinear_columns" value="true"/>
<parameter key="missing_values_handling" value="MeanImputation"/>
<parameter key="max_iterations" value="0"/>
<parameter key="max_runtime_seconds" value="0"/>
<operator activated="true" class="converters:h2o_logreg_2_example_set" compatibility="0.9.000" expanded="true" height="82" name="Logistic Regression to ExampleSet" origin="GENERATED_TUTORIAL" width="90" x="380" y="34"/>
<connect from_op="Retrieve Deals" from_port="output" to_op="Logistic Regression" to_port="training set"/>
<connect from_op="Logistic Regression" from_port="model" to_op="Logistic Regression to ExampleSet" to_port="mod"/>
<connect from_op="Logistic Regression to ExampleSet" from_port="exa" to_port="result 1"/>
