<?xml version="1.0" encoding="UTF-8"?><process version="9.7.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.7.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="concurrency:loop_files" compatibility="9.7.001" expanded="true" height="82" name="Loop Files" width="90" x="313" y="34"> <parameter key="filter_type" value="regex"/> <parameter key="filter_by_regex" value=".*xls"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="false"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.7.001" expanded="true" height="68" name="Read Excel" width="90" x="246" y="34"> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"/> <parameter key="read_not_matching_values_as_missings" value="true"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <connect from_port="file object" to_op="Read Excel" to_port="file"/> <connect from_op="Read Excel" from_port="output" to_port="output 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="9.7.001" expanded="true" height="82" name="Append" width="90" x="447" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <operator activated="true" class="write_excel" compatibility="9.7.001" expanded="true" height="103" name="Write Excel" width="90" x="581" y="34"> <parameter key="file_format" value="xlsx"/> <enumeration key="sheet_names"/> <parameter key="sheet_name" value="RapidMiner Data"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="number_format" value="#.0"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_op="Loop Files" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="file" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
