Java FileNotFoundException
User: "Repletion"
New Altair Community Member
Updated by Jocelyn
So a few days ago I installed the Rapidminer MLWizard extension. Upon installing it I tested it and it worked fine, now a few days later I am no longer able to use the wizard as it throws an "FileNotFoundException". I am getting the error when clicking settings->Automatic System Construction.
The log posts the following:
Jun 5, 2020 8:11:10 PM WARNING: Cannot initialize XML serialization. Probably the libraries xstream.jar and xpp.jar were not provided. XML serialization will not work!
Jun 5, 2020 8:11:10 PM WARNING: Cannot read object from XML serialization. Probably the libraries 'xstream.jar' and 'xpp.jar' were not provided.
1 - 1 of 11
    User: "David_A"
    unfortunately the ML Wizard extension is already quite old and no longer maintained by its developer (which is not RapidMiner).
    From its description I guess, that you can also use AutoModel or RapidMiner Go for a more convenient automated classification experience.
    Best,
    David
