# rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none), # or the number of input ports plus one if "use macros" parameter is set # if you want to use macros, use this instead and check "use macros" parameter: #def rm_main(data,macros): def rm_main(data): print('Hello, world!') # output can be found in Log View print(type(data)) #your code goes here #for example: data2 = pandas.DataFrame([3,5,77,8]) # connect 2 output ports to see the results return data, data2
rm_main()
