I used to have an earlier version of RapidMiner (9.0 i believe) that I have since upgraded for academic purposes. Every time I load the application, it crashes with the following message:
Java count not be launched. Errorcode:1
I have ran RapidMiner Studio.bat and got the following message:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000e1e76c1466, pid=9660, t
id=0x0000000000000ea8
# JRE version: OpenJDK Runtime Environment (8.0_232-b09) (build 1.8.0_232-b09)
# Java VM: OpenJDK 64-Bit Server VM (25.232-b09 mixed mode windows-amd64 compres
sed oops)
# Problematic frame:
# C [ssojho64.dll+0x11466]
# Failed to write core dump. Minidumps are not enabled by default on client vers
ions of Windows
# An error report file with more information is saved as:
# C:\WINDOWS\system32\hs_err_pid9660.log
# If you would like to submit a bug report, please visit:
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
This is the 64-bit installation of RapidMiner 9.6.0 on a 64-bit Windows 8.1 OS machine with 8GB of RAM.
