No Charts on Visualizations
JoãoFRF
Hey there everyone.
I just started using rapidminer, as I am using it in my university.
I'm here asking for help (I tried figuring it out with my teacher but no success), where I have no graphic what so ever on results -> visualizations.
Here is the print: imgur.com/TTcFYBd.png
Here is the neofetch of my system: imgur.com/he6Hcwn.png
I've tried using the legacy options and the html 5.
Thank you all in advance.
Visualization + Dashboards
Results View
BalazsBaranyRM
I'm actually using the Amazon Coretto Java VM 8 for Studio on Linux nowadays. It is also compatible with the new database connection dialogs.
With OpenJDK, I see:
- Upon start, the Cloud extension can't be loaded
- No visualizations
- Editing database connections doesn't work
Errors in the terminal:
Exception in thread "AWT-EventQueue-1" java.lang.UnsatisfiedLinkError: /home/barany/.RapidMiner/internal cache/browser7.3-ANY/libawt_helper.so: libjawt.so: Can't open shared object file: no such file or directory
Exception in thread "AWT-EventQueue-1" java.lang.NoClassDefFoundError: javafx/beans/property/StringProperty
at com.rapidminer.connection.gui.model.ConnectionModelConverter.fromConnection(ConnectionModelConverter.java:77)
at com.rapidminer.connection.gui.AbstractConnectionGUI.<init>(AbstractConnectionGUI.java:132)
at com.rapidminer.extension.jdbc.connection.gui.JDBCConnectionGUI.<init>(JDBCConnectionGUI.java:40)
So I guess we can only recommend the Coretto JDK for RapidMiner Studio on Linux.
Balázs
sgenzer
hi
@JoãoFRF
can you please share your rapidminer-studio.log file?
JoãoFRF
@sgenzer
Here it is : pastebin.com/raw/7h3ppz02
sgenzer
thanks
@JoãoFRF
. That helps. What's your computer hardware and operating system?
JoãoFRF
@sgenzer
I posted it on the question, I'm using mx linux, on a laptop, i7-7700hq and a 1050ti (no nvidia drivers installed because last time i installed them i had issues (it has conflicts with other softwares i use atm), but i have no need to install them anyways.)
sgenzer
yes that is what I suspected. We are aware of some issues with the visualizations on some Linux installations. Our resident Linux expert is
@BalazsBarany
so I will see if he has any insight here. Otherwise you may wish to use RapidMiner on any standard Windows / Mac machine.
Scott
JoãoFRF
@sgenzer
But it is the only feature that doesn't work, everything else seems alright, graphics work etc, just not in the visualizations tab
sgenzer
Yup. That's exactly what we have heard from time to time. Let's see what Balazs has to say.
BalazsBaranyRM
- No visualizations
Balázs
BalazsBaranyRM
BTW, this is the download link:
https://docs.aws.amazon.com/corretto/latest/corretto-8-ug/downloads-list.html
JoãoFRF
@BalazsBarany
And now how do I "force" rapidminer to use that java version?
BalazsBaranyRM
I set JAVA_HOME before calling RapidMiner. You can also put the following into your RapidMiner-Studio.sh at the beginning:
export JAVA_HOME=/usr/lib/jvm/java-1.8.0-amazon-corretto
Balázs
JoãoFRF
Worked like a charm.
Thank you so much!
JoãoFRF
In any case someone ends ups here with the same problem here's what I did.
As i'm in a debian based distro after getting told to use the amazon correto 8 I did this:
sudo dpkg --install java-1.8.0-amazon-corretto-jdk_8.242.07-1_amd64.deb
I downloaded the file here: docs.aws.amazon.com/corretto/latest/corretto-8-ug/downloads-list.html
sudo update-alternatives --config java
selected the number with the correct version and restarted rapidminer.
BalazsBaranyRM
Thanks
@JoãoFRF
for sharing the installation process.
I've heard from developers that the problem is only temporary, affecting version 9.5.
Studio 9.6 will also work with OpenJDK again, as it will bundle the necessary libraries.
Balázs
