I need help with opening topology-optimized parts. I use Altair Inspire 2022.3 at the University of Kaiserslautern and have written a Python program with which I run different calculations one after the other. With a small number of calculations it is no problem to open the results all in one file by selecting the green flag as soon as all calculations are finished. However, I cannot click on this flag when I run 729 calculations. Is there a way to open all results from the run history or the run folder in one document?
Another problem I have is when I try to set the thickness constraints below the recommended minimum thickness. It only calculates up to about 60% of the topology optimization and then aborts. Is this due to the processing power of my computer or to another reason?
Kind regards
Fynn Favier
