One of my students is using rapidminer on Mac Pro (Mojave) Java 8. The process has a label in the dataset and still its throwing an error stating "Input example set doesn't have label".
Label column in dataset is label and assigned during data loading into repository. I checked the process and it shows label column
I attached the process .rmp, dataset and log file.
@rfuentealba @sgenzer Thanks for your help
