<?xml version="1.0" encoding="UTF-8"?><process version="9.4.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="concurrency:loop_files" compatibility="9.4.001" expanded="true" height="82" name="Loop Files" width="90" x="179" y="34"> <parameter key="directory" value="your_excel_folder"/> <parameter key="filter_type" value="glob"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="true"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="false"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.4.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="447" y="85"> <parameter key="generator_type" value="attribute functions"/> <parameter key="number_of_examples" value="1"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"> <parameter key="my_excel_file_name" value="%{file_name}"/> </list> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> <description align="center" color="transparent" colored="false" width="126">create a single record with the excel name</description> </operator> <operator activated="true" class="replace" compatibility="9.4.001" expanded="true" height="82" name="Replace" width="90" x="581" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="my_excel_file_name"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value=".xlsx"/> <description align="center" color="transparent" colored="false" width="126">remove the extension</description> </operator> <operator activated="true" class="split" compatibility="9.4.001" expanded="true" height="82" name="Split" width="90" x="715" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="my_excel_file_name"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value="_"/> <parameter key="split_mode" value="ordered_split"/> <description align="center" color="transparent" colored="false" width="126">split by _</description> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_port="output 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">loop through all excel files and get the name split</description> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.2.000" expanded="true" height="82" name="Append (Superset)" width="90" x="313" y="34"> <description align="center" color="transparent" colored="false" width="126">add all together</description> </operator> <connect from_op="Loop Files" from_port="output 1" to_op="Append (Superset)" to_port="example set 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
