I would ask if it's possible to get Static Safety Factor in Simlab as Output in the results. Looking at the result request is not a default activable output.
How can I add into the solver output throught Simlab?
Thanks
Hello Ludovico,
This result request is available when using Fatigue Solutions with SimLab otherwise this output request does not exist solver wise. In general, the Factor of Safety (minimum) is the division between two numbers.
Factor of Safety (minimum) = Allowed Stress/Maximum Stress.
You can do that division manually on your own.
I hope this helps.
Ioannis Makris
