Radoop Hive connection test fail on 'Create permanent UDFs'
I'm trying to setup radoop connection to a secured cloudera cluster with Sentry enabled.
Hadoop Admin has manually created UDFs in my test db, but I'm still getting errors:
[Sep 27, 2019 3:56:09 PM] WARNING: The version of the rapidminer_libs jar on the HADOOP_CLASSPATH (9.0) is for another version of RapidMiner Radoop. Current version: 9.3. Please notify your Hadoop administrator about this issue.
[Sep 27, 2019 3:56:09 PM] WARNING: The current version (9.3) of the rapidminer_libs jar could not be found on the HADOOP_CLASSPATH. Please notify your Hadoop administrator about this issue.
[Sep 27, 2019 3:56:10 PM] SEVERE: Test failed: Create permanent UDFs
[Sep 27, 2019 3:56:10 PM]: Cleaning after test: Create permanent UDFs
[Sep 27, 2019 3:56:10 PM]: Cleaning after test: UDF jar upload
[Sep 27, 2019 3:56:10 PM]: Cleaning after test: Fetch dynamic settings
[Sep 27, 2019 3:56:10 PM]: Cleaning after test: Hive connection
[Sep 27, 2019 3:56:10 PM]: Total time: 23.705s
[Sep 27, 2019 3:56:10 PM]: com.rapidminer.operator.OperatorException: UDFs are claimed to be installed manually, but the following functions are not available in database 'test_db': [test_db.r3_is_eq, test_db.r3_greatest, test_db.r3_gaussian_rand, test_db.r3_which, test_db.r3_least, test_db.r3_max_index, test_db.r3_pivot_collect_count, test_db.r3_nth, test_db.r3_correlation_matrix, test_db.r3_pivot_collect_avg, test_db.r3_pivot_collect_min, test_db.r3_sum_collect, test_db.r3_add_file, test_db.r3_pivot_createtable, test_db.r3_score_naive_bayes, test_db.r3_pivot_collect_sum, test_db.r3_pivot_collect_max, test_db.r3_sleep, test_db.r3_esc]
at eu.radoop.datahandler.hive.UDFHandler.ensureRadoopUDFs(UDFHandler.java:839)
at eu.radoop.connections.service.test.connection.TestCreatePermanentUDFs.call(TestCreatePermanentUDFs.java:46)
at eu.radoop.connections.service.test.connection.TestCreatePermanentUDFs.call(TestCreatePermanentUDFs.java:26)
at eu.radoop.connections.service.test.RadoopTestContext.lambda$runTest$1(RadoopTestContext.java:280)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
I can confirm all required UDFs are already created by running: hive -e 'use test_db; show functions;'
test_db.r3_add_file
test_db.r3_apply_model
test_db.r3_esc
test_db.r3_greatest
test_db.r3_is_eq
test_db.r3_least
test_db.r3_nth
test_db.r3_sleep
test_db.r3_which
What should I do to fix the issue now? Any suggestion would be much appreciated.
Thanks
test_db.r3_add_file
test_db.r3_esc
test_db.r3_greatest
test_db.r3_is_eq
test_db.r3_least
test_db.r3_nth
test_db.r3_sleep
test_db.r3_which
Thanks
1 - 3 of
31
sgenzer
cc @asimon
Have you done this already?
Full doc is available here: https://docs.cloudera.com/documentation/enterprise/5-16-x/topics/cm_mc_hive_udf.html
I would also recommend to update the rapidminer parcel as well so that the warnings could also go away.
