See the second tutorial for examples. As discussed in detail in the description, this Operator supports several different formats for the input data.
<?xml version="1.0" encoding="UTF-8"?><process version="9.4.000-BETA2"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000-BETA2" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value="yhuang@rapidminer.com"/> <parameter key="process_duration_for_mail" value="1"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.4.000-BETA2" expanded="true" height="68" name="Retrieve تراکنش-20" width="90" x="313" y="34"> <parameter key="repository_entry" value="//RM YY Loal Repository/from Community/data_tmp/تراکنش-20"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="9.4.000-BETA2" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="aggregate" compatibility="9.4.000-BETA2" expanded="true" height="82" name="Aggregate" width="90" x="581" y="34"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="ItemID" value="concatenation"/> <parameter key="ItemName" value="concatenation"/> </list> <parameter key="group_by_attributes" value="dt|CustomerID"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.4.000-BETA2" expanded="true" height="82" name="Select Attributes" width="90" x="715" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="CustomerID|concat(ItemName)"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="set_role" compatibility="9.4.000-BETA2" expanded="true" height="82" name="Set Role" width="90" x="849" y="34"> <parameter key="attribute_name" value="CustomerID"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="concurrency:fp_growth" compatibility="9.4.000-BETA2" expanded="true" height="82" name="FP-Growth" width="90" x="983" y="34"> <parameter key="input_format" value="item list in a column"/> <parameter key="item_separators" value="|"/> <parameter key="use_quotes" value="false"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="trim_item_names" value="true"/> <parameter key="min_requirement" value="frequency"/> <parameter key="min_support" value="0.95"/> <parameter key="min_frequency" value="5"/> <parameter key="min_items_per_itemset" value="1"/> <parameter key="max_items_per_itemset" value="0"/> <parameter key="max_number_of_itemsets" value="1000000"/> <parameter key="find_min_number_of_itemsets" value="true"/> <parameter key="min_number_of_itemsets" value="100"/> <parameter key="max_number_of_retries" value="15"/> <parameter key="requirement_decrease_factor" value="0.9"/> <enumeration key="must_contain_list"/> </operator> <operator activated="true" class="create_association_rules" compatibility="9.4.000-BETA2" expanded="true" height="82" name="Create Association Rules (2)" width="90" x="1184" y="85"> <parameter key="criterion" value="confidence"/> <parameter key="min_confidence" value="0.8"/> <parameter key="min_criterion_value" value="0.8"/> <parameter key="gain_theta" value="2.0"/> <parameter key="laplace_k" value="1.0"/> </operator> <connect from_op="Retrieve تراکنش-20" from_port="output" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="FP-Growth" to_port="example set"/> <connect from_op="FP-Growth" from_port="example set" to_port="result 1"/> <connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules (2)" to_port="item sets"/> <connect from_op="Create Association Rules (2)" from_port="rules" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
