I need some help with agglomerative clustering please
User: "Janito"
New Altair Community Member
Updated by Jocelyn
Hello everyone! I am working with RapidMiner for a week now and I cannot figure out how to solve my problem or to be more specific: I need some inspiration for the work with RapidMiner.
Here is my starting point:
  • I have a csv-file which contains several examples of data from sensors of a fictional production machine. The first row will be a timestamp which contains the time when the sensor collected data. The second one will be the name of the event which happened. Attached you will find some data example as I cannot upload it here.
  • As you can see, from time to time an error has accurred (yellow mark) which I want to analyse why it happened. The assumption is that events which happened in a short time before "error occurred" have a higher possibility to cause this problem. Events which happened a long time before the error occurred have a lesser possibility.
  • After doing the tutorial and reading some questions from the community I decided to try an agglomerative cluster to cluster all the events which occurred in the time before the event "error occured".
  • That is why I want to take the event "error occurred" as my zero and measure the time distances between zero and the events happened before in order to determine which failure of a sensor will probably lend into the the event "error occurred".
  • My thought was to maybe split the data at a first step after each "error occurred" into smaller sub-files and try to apply the agglomerative cluster.
Could you guys please give me an inspiration to solve my problem or could you please tell me if this is possible like I presented my ideas?
Thanks in advance and have a nice week!
Greetings
Janito
1 - 1 of 11
    User: "sgenzer"
    Accepted Answer
    hi @Janito I'm sure there is an easier way to do this, but this works :smile:
    <?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
        <parameter key="random_seed" value="-1"/>
        <process expanded="true">
          <operator activated="true" class="utility:create_exampleset" compatibility="9.2.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34">
            <parameter key="generator_type" value="comma separated text"/>
            <parameter key="number_of_examples" value="100"/>
            <parameter key="use_stepsize" value="false"/>
            <list key="function_descriptions"/>
            <parameter key="add_id_attribute" value="false"/>
            <list key="numeric_series_configuration"/>
            <list key="date_series_configuration"/>
            <list key="date_series_configuration (interval)"/>
            <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
            <parameter key="time_zone" value="America/New_York"/>
            <parameter key="input_csv_text" value="timestamp,event name&#10;8:00,Sensor A false&#10;8:15,Sensor B false&#10;8:16,Sensor C false&#10;8:34,Sensor A false&#10;8:36,Sensor C false&#10;8:40,Sensor A false&#10;8:40,Error occurred&#10;9:03,Sensor B false&#10;9:10,Sensor D false&#10;9:12,Sensor B false&#10;9:15,Sensor A false&#10;9:15,Error occurred&#10;9:20,Sensor B false"/>
            <parameter key="column_separator" value=","/>
            <parameter key="parse_all_as_nominal" value="false"/>
            <parameter key="decimal_point_character" value="."/>
            <parameter key="trim_attribute_names" value="true"/>
          <operator activated="true" class="nominal_to_date" compatibility="9.2.001" expanded="true" height="82" name="Nominal to Date" width="90" x="179" y="34">
            <parameter key="attribute_name" value="timestamp"/>
            <parameter key="date_type" value="time"/>
            <parameter key="date_format" value="HH:mm"/>
            <parameter key="time_zone" value="SYSTEM"/>
            <parameter key="locale" value="English (United States)"/>
            <parameter key="keep_old_attribute" value="false"/>
          <operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34">
              <parameter key="flag" value="if(prefix([event name],1)==&quot;E&quot;,1,0)"/>
            </list>
            <parameter key="keep_all" value="true"/>
          <operator activated="true" class="operator_toolbox:generate_session_id" compatibility="2.0.001" expanded="true" height="82" name="Generate Session ID" width="90" x="447" y="34">
            <parameter key="date_attribute" value="flag"/>
            <parameter key="gap_threshold" value="0.5"/>
            <parameter key="gap_unit" value="none"/>
            <parameter key="use_absolutes" value="false"/>
          <operator activated="true" class="numerical_to_polynominal" compatibility="9.2.001" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="581" y="34">
            <parameter key="attribute" value="Session id"/>
            <parameter key="value_type" value="numeric"/>
            <parameter key="except_value_type" value="real"/>
            <parameter key="block_type" value="value_series"/>
            <parameter key="except_block_type" value="value_series_end"/>
          <operator activated="true" class="time_series:lag_series" compatibility="9.2.001" expanded="true" height="82" name="Lag" width="90" x="715" y="34">
            <list key="attributes">
              <parameter key="Session id" value="1"/>
            </list>
            <parameter key="overwrite_attributes" value="false"/>
            <parameter key="extend_exampleset" value="false"/>
          <operator activated="true" class="replace_missing_values" compatibility="9.2.001" expanded="true" height="103" name="Replace Missing Values" width="90" x="849" y="34">
            <parameter key="return_preprocessing_model" value="false"/>
            <parameter key="create_view" value="false"/>
            <parameter key="attribute" value="Session id-1"/>
            <parameter key="default" value="value"/>
            <list key="columns"/>
            <parameter key="replenishment_value" value="0"/>
          <operator activated="true" class="concurrency:loop_values" compatibility="9.2.001" expanded="true" height="82" name="Loop Values" width="90" x="983" y="34">
            <parameter key="iteration_macro" value="loop_value"/>
            <parameter key="reuse_results" value="false"/>
            <parameter key="enable_parallel_execution" value="false"/>
              <operator activated="true" class="filter_examples" compatibility="9.2.001" expanded="true" height="103" name="Filter Examples" width="90" x="45" y="34">
                <parameter key="parameter_expression" value=""/>
                <parameter key="condition_class" value="custom_filters"/>
                <parameter key="invert_filter" value="false"/>
                <list key="filters_list">
                  <parameter key="filters_entry_key" value="Session id-1.equals.%{loop_value}"/>
                </list>
                <parameter key="filters_logic_and" value="true"/>
                <parameter key="filters_check_metadata" value="true"/>
              <operator activated="true" class="extract_macro" compatibility="9.2.001" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="34">
                <parameter key="macro" value="min"/>
                <parameter key="macro_type" value="statistics"/>
                <parameter key="statistics" value="min"/>
                <list key="additional_macros"/>
                <description align="center" color="transparent" colored="false" width="126">min</description>
              <operator activated="true" class="extract_macro" compatibility="9.2.001" expanded="true" height="68" name="Extract Macro (2)" width="90" x="313" y="34">
                <parameter key="macro" value="max"/>
                <parameter key="statistics" value="max"/>
              <operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="447" y="34">
                  <parameter key="timeDifferenceInMinutes" value="(eval(%{max})-eval(%{min}))/(1000*60)"/>
                </list>
              <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/>
              <connect from_op="Filter Examples" from_port="example set output" to_op="Extract Macro" to_port="example set"/>
              <connect from_op="Extract Macro" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/>
              <connect from_op="Extract Macro (2)" from_port="example set" to_op="Generate Attributes (2)" to_port="example set input"/>
              <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="output 1"/>
              <portSpacing port="sink_output 1" spacing="0"/>
              <portSpacing port="sink_output 2" spacing="0"/>
            </process>
          <operator activated="true" class="append" compatibility="9.2.001" expanded="true" height="82" name="Append" width="90" x="1117" y="34">
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
            <parameter key="merge_type" value="all"/>
          <connect from_op="Create ExampleSet" from_port="output" to_op="Nominal to Date" to_port="example set input"/>
          <connect from_op="Nominal to Date" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_op="Generate Session ID" to_port="exa"/>
          <connect from_op="Generate Session ID" from_port="exa" to_op="Numerical to Polynominal" to_port="example set input"/>
          <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Lag" to_port="example set input"/>
          <connect from_op="Lag" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/>
          <connect from_op="Replace Missing Values" from_port="example set output" to_op="Loop Values" to_port="input 1"/>
          <connect from_op="Loop Values" from_port="output 1" to_op="Append" to_port="example set 1"/>
          <connect from_op="Append" from_port="merged set" to_port="result 1"/>
        </process>
    </process>
    Scott
