matches(text,%{prefix}+".+")
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="utility:create_exampleset" compatibility="9.2.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="313" y="85"><br> <parameter key="generator_type" value="comma separated text"/><br> <parameter key="number_of_examples" value="100"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"/><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="input_csv_text" value="text english"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="set_macro" compatibility="9.2.000" expanded="true" height="82" name="Set Macro" width="90" x="447" y="85"><br> <parameter key="macro" value="prefix"/><br> <parameter key="value" value="eng"/><br> </operator><br> <operator activated="true" class="filter_examples" compatibility="9.2.000" expanded="true" height="103" name="Filter Examples" width="90" x="581" y="85"><br> <parameter key="parameter_expression" value="matches(text,%{prefix}+".+")"/><br> <parameter key="condition_class" value="expression"/><br> <parameter key="invert_filter" value="false"/><br> <list key="filters_list"/><br> <parameter key="filters_logic_and" value="true"/><br> <parameter key="filters_check_metadata" value="true"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Set Macro" to_port="through 1"/><br> <connect from_op="Set Macro" from_port="through 1" to_op="Filter Examples" to_port="example set input"/><br> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
