<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="set_macro" compatibility="9.1.000" expanded="true" height="82" name="Set Macro" width="90" x="112" y="34"> <parameter key="macro" value="database"/> <parameter key="value" value="mongo_1"/> </operator> <operator activated="true" class="branch" compatibility="9.1.000" expanded="true" height="82" name="choose" width="90" x="246" y="34"> <parameter key="condition_type" value="expression"/> <parameter key="expression" value="equals(%{database}, "mongo_1")"/> <parameter key="io_object" value="AHCDescribedCluster"/> <parameter key="return_inner_output" value="false"/> <process expanded="true"> <operator activated="true" class="nosql:mongodb_document_reader" compatibility="9.0.000" expanded="true" height="103" name="Read MongoDB" width="90" x="179" y="34"> <parameter key="mongodb_instance" value="mongo_1"/> <parameter key="collection" value="coll1"/> <parameter key="sort_documents" value="false"/> <parameter key="limit_results" value="false"/> <parameter key="skip" value="0"/> </operator> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="nosql:mongodb_document_reader" compatibility="9.0.000" expanded="true" height="103" name="Read MongoDB (2)" width="90" x="179" y="34"> <parameter key="mongodb_instance" value="mongo_2"/> <parameter key="collection" value="coll1"/> <parameter key="sort_documents" value="false"/> <parameter key="limit_results" value="false"/> <parameter key="skip" value="0"/> </operator> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_op="Set Macro" from_port="through 1" to_op="choose" to_port="condition"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="set_macro" compatibility="9.1.000" expanded="true" height="68" name="Set Macro" width="90" x="45" y="34"> <parameter key="macro" value="mycoll"/> <parameter key="value" value="some_collection"/> </operator> <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document (4)" width="90" x="179" y="34"> <parameter key="text" value="{aggregate: "%{mycoll}",pipeline: [ {$match: { "Something": "something" } }, {$project:{ ... }} ],cursor: {},allowDiskUse: true}"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:replace_tokens" compatibility="8.1.000" expanded="true" height="68" name="Replace Tokens (8)" width="90" x="313" y="34"> <list key="replace_dictionary"> <parameter key="\n" value=" "/> </list> </operator> <operator activated="true" class="nosql:mongodb_command" compatibility="9.0.000" expanded="true" height="68" name="Execute MongoDB Command (5)" width="90" x="447" y="34"> <parameter key="mongodb_instance" value="my_database"/> </operator> <connect from_op="Create Document (4)" from_port="output" to_op="Replace Tokens (8)" to_port="document"/> <connect from_op="Replace Tokens (8)" from_port="document" to_op="Execute MongoDB Command (5)" to_port="command"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
