<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000-SNAPSHOT" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="85"> <parameter key="generator_type" value="comma_separated_text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="input_csv_text" value="1_distance,1_speed,1_time,2_distance,2_speed,2_time,3_distance,3_speed,3_time,4_distance,4_speed,4_time 1,2,3,4,5,6,7,8,9,10,11,12"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="transpose" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Transpose" width="90" x="246" y="85"/> <operator activated="true" class="split" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Split" width="90" x="380" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="split_pattern" value="_"/> <parameter key="split_mode" value="ordered_split"/> </operator> <operator activated="true" class="subprocess" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Turbo Prep Process" width="90" x="514" y="85"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Subprocess" width="90" x="45" y="34"> <process expanded="true"> <operator activated="true" class="nominal_to_text" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Nominal to Text" width="90" x="45" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <description align="center" color="transparent" colored="false" width="126">Change all categorical columns to text</description> </operator> <operator activated="true" class="text_to_nominal" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Text to Nominal" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="text"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="text"/> <parameter key="block_type" value="value_matrix"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <description align="center" color="transparent" colored="false" width="126">Change all text columns to nominal</description> </operator> <operator activated="true" class="numerical_to_real" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Numerical to Real" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <description align="center" color="transparent" colored="false" width="126">Change all numerical columns to real</description> </operator> <connect from_port="in 1" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Text to Nominal" to_port="example set input"/> <connect from_op="Text to Nominal" from_port="example set output" to_op="Numerical to Real" to_port="example set input"/> <connect from_op="Numerical to Real" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Unify column types</description> </operator> <operator activated="true" class="subprocess" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Pivot Subprocess" origin="GENERATED_TURBOPREP" width="90" x="179" y="34"> <process expanded="true"> <operator activated="true" class="blending:pivot" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Pivot" origin="GENERATED_TURBOPREP" width="90" x="45" y="34"> <parameter key="group_by_attributes" value="id_1"/> <parameter key="column_grouping_attribute" value="id_2"/> <list key="aggregation_attributes"> <parameter key="att_1" value="average"/> </list> <parameter key="use_default_aggregation" value="false"/> <parameter key="default_aggregation_function" value="first"/> </operator> <operator activated="true" class="order_attributes" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Reorder Attributes" origin="GENERATED_TURBOPREP" width="90" x="179" y="34"> <parameter key="sort_mode" value="user specified"/> <parameter key="attribute_ordering" value="id_1|average(att_1)_distance|average(att_1)_speed|average(att_1)_time"/> <parameter key="use_regular_expressions" value="false"/> <parameter key="handle_unmatched" value="append"/> <parameter key="sort_direction" value="ascending"/> </operator> <connect from_port="in 1" to_op="Pivot" to_port="input"/> <connect from_op="Pivot" from_port="output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="Reorder Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Pivot to [group by = id_1] with [columns = id_2] and [aggregates = att_1]</description> </operator> <operator activated="true" class="order_attributes" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Reorder Attributes (2)" width="90" x="313" y="34"> <parameter key="sort_mode" value="user specified"/> <parameter key="attribute_ordering" value="id_1|average(att_1)_distance|average(att_1)_speed|average(att_1)_time"/> <parameter key="use_regular_expressions" value="false"/> <parameter key="handle_unmatched" value="append"/> <parameter key="sort_direction" value="ascending"/> <description align="center" color="transparent" colored="false" width="126">Ensure order of columns matches the table view.</description> </operator> <connect from_port="in 1" to_op="Subprocess" to_port="in 1"/> <connect from_op="Subprocess" from_port="out 1" to_op="Pivot Subprocess" to_port="in 1"/> <connect from_op="Pivot Subprocess" from_port="out 1" to_op="Reorder Attributes (2)" to_port="example set input"/> <connect from_op="Reorder Attributes (2)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">TP Operations: Pivot</description> </operator> <operator activated="true" class="parse_numbers" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Parse Numbers" width="90" x="648" y="85"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="unparsable_value_handling" value="fail"/> </operator> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.7.000" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="112" y="289"> <parameter key="generator_type" value="comma_separated_text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="input_csv_text" value="id,longitude,latitude 1,10,20 2,30,40 3,50,60 4,70,80"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Set Role" width="90" x="380" y="238"> <parameter key="attribute_name" value="id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="set_role" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Set Role (2)" width="90" x="782" y="85"> <parameter key="attribute_name" value="id_1"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Join" width="90" x="916" y="187"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"> <parameter key="id_1" value="id"/> </list> <parameter key="keep_both_join_attributes" value="false"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Turbo Prep Process" to_port="in 1"/> <connect from_op="Turbo Prep Process" from_port="out 1" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Create ExampleSet (2)" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
