hi community,
I have successfully installed and configured hadoop 2.6.2, hive 2.1.1 and spark 2.3.1. when i run jps i have this:
1472 NameNode
3856 DataNode
12756 Jps
14164 SparkSubmit
14228 NodeManager
7544 GUILauncher
10860 RunJar
12524 ResourceManager
<SPAN>when i m trying to configure hadoop with rapidminer it gives the below error:<BR /></SPAN>
[Aug 12, 2018 6:19:50 PM]: --------------------------------------------------
[Aug 12, 2018 6:19:50 PM]: Connection test for 'hadoop' started.
[Aug 12, 2018 6:19:50 PM]: Removed test Kerberos beacuse Security is not enabled
[Aug 12, 2018 6:19:50 PM]: Using Radoop version 9.0.0.
[Aug 12, 2018 6:19:50 PM]: Running 11 tests: [Hive connection, Fetch dynamic settings, Java version, HDFS, MapReduce, Radoop temporary directory, MapReduce staging directory, Spark staging directory, Spark assembly jar existence, UDF jar upload, Create permanent UDFs]
[Aug 12, 2018 6:19:50 PM]: Running test 1/11: Hive connection
[Aug 12, 2018 6:19:50 PM]: Hive server 2 connection (localhost:10000) test started.
[Aug 12, 2018 6:19:51 PM] SEVERE: Test failed: Hive connection
[Aug 12, 2018 6:19:51 PM]: Cleaning after test: Hive connection
[Aug 12, 2018 6:19:51 PM]: Total time: 0.059s
[Aug 12, 2018 6:19:51 PM]: java.lang.NoClassDefFoundError: Could not initialize class org.apache.hive.jdbc.HiveConnection
	at org.apache.hive.jdbc.HiveDriver.connect(HiveDriver.java:107)
	at eu.radoop.classloader.HiveDriverShim.connect(HiveDriverShim.java:71)
	at java.sql.DriverManager.getConnection(DriverManager.java:664)
	at java.sql.DriverManager.getConnection(DriverManager.java:247)
	at eu.radoop.datahandler.hive.PooledStatement.lambda$connect$0(PooledStatement.java:214)
	at eu.radoop.tools.ExceptionTools.check(ExceptionTools.java:301)
	at eu.radoop.datahandler.hive.PooledStatement.connect(PooledStatement.java:189)
	at eu.radoop.datahandler.hive.StatementPool.getStatement(StatementPool.java:314)
	at eu.radoop.datahandler.hive.StatementPool.getStatement(StatementPool.java:181)
	at eu.radoop.datahandler.hive.HiveHandler.runFastQueryPrivilegedAction(HiveHandler.java:1010)
	at eu.radoop.datahandler.hive.HiveHandler.runFastQuery(HiveHandler.java:986)
	at eu.radoop.datahandler.hive.HiveHandler.getSimpleListFast(HiveHandler.java:2575)
	at eu.radoop.datahandler.hive.HiveHandler.getTableList(HiveHandler.java:2507)
	at eu.radoop.connections.service.test.connection.TestHiveConnection.call(TestHiveConnection.java:51)
	at eu.radoop.connections.service.test.connection.TestHiveConnection.call(TestHiveConnection.java:25)
	at eu.radoop.connections.service.test.RadoopTestContext.lambda$runTest$1(RadoopTestContext.java:279)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
[Aug 12, 2018 6:19:51 PM] SEVERE: java.lang.NoClassDefFoundError: Could not initialize class org.apache.hive.jdbc.HiveConnection
[Aug 12, 2018 6:19:51 PM] SEVERE: Hive server 2 connection test failed. Please check that the server/daemon runs and is accessible on the address and port you specified.
[Aug 12, 2018 6:19:51 PM] SEVERE: Connection test for 'hadoop' failed.
I work on apache distribution 2.1.1 on windows 8.1 and apache port are default port (10000).
I don't know what is the problem, I'm new with hadoop and hive, is missing some jar files or versions are not compatible??
Thanks in advance,
<SPAN><BR /><BR /><BR /></SPAN>
