Hi All-
I'm new to the RM community and this is my first forum post (so please go easy
I'm trying to do basic arithmetic with a macro; I want to assign a value to a macro and then decrement it by one. (The sad thing is that there is probably a better way to achieve the same end for the process, but I've invested so much time, at this point, I want to figure out how to do this.)
I've tried a number of approaches:
using eval(%{MACRO_NAME}) syntax
using #{MACRO_NAME} syntax
eval(%{MACRO_NAME}) - 1
eval(%{MACRO_NAME} -1)
using one macro (setting MACRO_NAME value and then setting MACRO_NAME to MACRO_NAME - 1
using two macros (setting MACRO_NAME value and then setting MACRO2 to MACRO_NAME - 1
using the Generate Macro operator
using the Set Macro operator
I'm having trouble attaching the process, so apologies for not posting it.
Thank you in advance for the help!
-Noel
