I've shared my process below and included my xml to illustrate my problem since I can't explain my problem very clearly. What I'm trying to do is to generate a new attribute based on another attribute that is built with a macro (loop_value) and then renamed. However in the generate attributes I cannot use the expression previous_eval(%{loop_value}) (in which "previous_" is part of the renaming process). Does anybody knows how to work around this problem? Sorry if I'm being vague, but the xml should make it more clear.
Thanks!
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="8.1.000" expanded="true" height="68" name="Read CSV" width="90" x="112" y="34">
<parameter key="csv_file" value="C:\Users\lise.hanssens\Downloads\test_macro.csv"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="windows-1252"/>
<list key="data_set_meta_data_information"/>
<operator activated="true" class="concurrency:loop_values" compatibility="8.1.000" expanded="true" height="82" name="Loop Values" width="90" x="246" y="34">
<parameter key="attribute" value="activity"/>
<operator activated="true" class="multiply" compatibility="8.1.000" expanded="true" height="103" name="Multiply" width="90" x="179" y="85"/>
<operator activated="true" breakpoints="after" class="rename_by_replacing" compatibility="8.1.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="313" y="34">
<parameter key="replace_what" value="(.+)"/>
<parameter key="replace_by" value="previous_$1"/>
<operator activated="true" class="concurrency:join" compatibility="8.1.000" expanded="true" height="82" name="Join" width="90" x="447" y="85">
<parameter key="join_type" value="right"/>
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="previous_id" value="id"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="8.1.000" expanded="true" height="82" name="Generate Attributes" width="90" x="581" y="85">
<parameter key="previous_activity" value="if(missing(eval(%{loop_value}), previous_eval(%{loop_value}), eval(%{loop_value}))"/>
</list>
<connect from_port="input 1" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Join" to_port="right"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Join" from_port="join" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Loop Values" to_port="input 1"/>
<connect from_op="Loop Values" from_port="output 1" to_port="result 1"/>
</process>
</process>
