Hi
Im trying to create a fat jar using maven in eclipse, so that i can run a rmp process. In the fat jar i have all the dependencies and extensions (concurrency, jdbc_connectors etc) that my rmp process needs to execute the process.
I am using maven in eclipse to create the fat jar.
When my fat jar is created and i run the jar file, i keep getting the error
"'concurrency:parallel_decision_tree' is unknown. Possibly you must install a plugin for operators of group 'concurrency'"
and,
'jdbc_connectors:read_database' is unknown. Possibly you must install a plugin for operators of group 'jdbc_connectors'
in Eclipse under the maven dependencies i have all the extensions that i need and also in the POM.xml i have stated all the dependencies for this process.
I do not know why the fat jar is telling me that it cannot find the plugins, even thoug the jar files for these plugins are included.
My RMP process is very simple, it just reads a DataBase, implements a decision tree and then it writes and excel file.
Here is the error i am getting:
INFO: <em class="error">The operator class 'jdbc_connectors:read_database' is unknown. Possibly you must install a plugin for operators of group 'jdbc_connectors'.</em>
Jun 18, 2018 10:44:45 AM com.rapidminer.io.process.XMLImporter parseOperator
INFO: The parameter 'define_connection' is unknown for operator 'Read Database' (" dummy ")."
INFO: The parameter 'database_system' is unknown for operator 'Read Database' (" dummy ")."
INFO: The parameter 'define_query' is unknown for operator 'Read Database' (" dummy ")."
INFO: The parameter 'use_default_schema' is unknown for operator 'Read Database' (" dummy ")."
INFO: The parameter 'prepare_statement' is unknown for operator 'Read Database' (" dummy ")."
INFO: The parameter 'parameters' of type enumeration is unknown for operator 'Read Database' (" dummy ")."
INFO: The parameter 'datamanagement' is unknown for operator 'Read Database' (" dummy ")."
INFO: The parameter 'data_management' is unknown for operator 'Read Database' (" dummy ")."
Jun 18, 2018 10:44:45 AM com.rapidminer.io.process.XMLImporter addMessage
INFO: <em class="error">The operator class 'concurrency:parallel_decision_tree' is unknown. Possibly you must install a plugin for operators of group 'concurrency'.</em>
INFO: The parameter 'criterion' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'maximal_depth' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'apply_pruning' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'confidence' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'apply_prepruning' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'minimal_gain' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'minimal_leaf_size' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'minimal_size_for_split' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: The parameter 'number_of_prepruning_alternatives' is unknown for operator 'Decision Tree' (" dummy ")."
INFO: <em class="error">The output port <var>output</var> is unknown at operator <var>Read Database</var>.</em>
INFO: <em class="error">The input port <var>training set</var> is unknown at operator <var>Decision Tree</var>.</em>
INFO: <em class="error">The output port <var>model</var> is unknown at operator <var>Decision Tree</var>.</em>
Exception in thread "main" java.lang.NullPointerException
at com.testingJar.tesingJar.App.main(App.java:70)
Here is my POM.xml file from Maven in eclipse:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.testingJar</groupId>
<artifactId>tesingJar</artifactId>
<version>0.0.1-SNAPSHOT</version>
<packaging>jar</packaging>
<name>tesingJar</name>
<url>http://maven.apache.org</url>
<properties>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
</properties>
<dependencies>
<dependency>
<groupId>org.apache.commons</groupId>
<artifactId>commons-lang3</artifactId>
<version>3.7</version>
</dependency>
<dependency>
<groupId>com.rapidminer.studio</groupId>
<artifactId>rapidminer-studio-core</artifactId>
<version>7.2.0</version>
</dependency>
<dependency>
<groupId>concurrent</groupId>
<artifactId>concurrent</artifactId>
<version>1.3.4</version>
</dependency>
<dependency>
<groupId>com.rapidminer.extension</groupId>
<artifactId>
rapidminer-extension-concurrency-8.2.0-all
</artifactId>
<version>1.0</version>
</dependency>
<dependency>
<artifactId>
rapidminer-extension-jdbc-connectors-8.2.0-all
</artifactId>
</dependency>
<dependency>
<artifactId>
rapidminer-extension-advanced-file-connectors-8.2.0-all
</artifactId>
<version>8.2.0</version>
</dependency>
<dependency>
<artifactId>rapidminer-extension-legacy-8.2.0-all</artifactId>
</dependency>
<dependency>
<artifactId>
rapidminer-extension-productivity-8.2.0-all
</artifactId>
</dependency>
<dependency>
<artifactId>
rapidminer-extension-professional-8.2.0-all
</artifactId>
</dependency>
<dependency>
<artifactId>
rapidminer-extension-remote-repository-8.2.0-all
</artifactId>
</dependency>
<dependency>
<artifactId>cloud_connectivity-8.2.0-all</artifactId>
</dependency>
<dependency>
<artifactId>cloud_execution-8.1.0-all</artifactId>
<version>8.1.0</version>
</dependency>
<dependency>
<artifactId>dataeditor-7.3.0-all</artifactId>
<version>7.3.0</version>
</dependency>
<dependency>
<artifactId>h2o-8.2.0-all</artifactId>
</dependency>
<dependency>
<artifactId>operator_recommender-8.2.0-all</artifactId>
</dependency>
</dependencies>
<repositories>
<repository>
<id>rapidminer</id>
<url>https://maven.rapidminer.com/content/groups/public/</url>
</repository>
</repositories>
<build>
<plugins>
<!-- download source code in Eclipse, best practice -->
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-eclipse-plugin</artifactId>
<version>2.9</version>
<configuration>
<downloadSources>true</downloadSources>
<downloadJavadocs>false</downloadJavadocs>
</configuration>
</plugin>
<!-- Set a compiler level -->
<plugin>
<artifactId>maven-compiler-plugin</artifactId>
<version>2.3.2</version>
<configuration>
<source>${jdk.version}</source>
<target>${jdk.version}</target>
</configuration>
</plugin>
<plugin>
<artifactId>maven-shade-plugin</artifactId>
<version>3.1.1</version>
<executions>
<!-- Run Shade goal on package phase -->
<execution>
<phase>package</phase>
<goals>
<goal>shade</goal>
</goals>
<configuration>
<transformers>
<transformer
implementation= "org.apache.maven.plugins.shade.resource.ManifestResourceTransformer">
<mainClass>com.testingJar.tesingJar.App</mainClass>
</transformer>
</transformers>
<filters>
<filter>
<artifact>junit:junit</artifact>
<includes>
<include>junit/framework/**</include>
<include>org/junit/**</include>
</includes>
<excludes>
<exclude>org/junit/experimental/**</exclude>
<exclude>org/junit/runners/**</exclude>
</excludes>
</filter>
<filter>
<artifact>*:*</artifact>
<excludes>
<exclude>META-INF/*.SF</exclude>
<exclude>META-INF/*.DSA</exclude>
<exclude>META-INF/*.RSA</exclude>
</excludes>
</filter>
</filters>
</configuration>
</execution>
</executions>
</plugin>
</plugins>
</build>
</project>
all the extensions are in the remote repository .m2
Please hel me with this issue i am very frustrated about this
I appreciate any help or orientation
Thank you
