flux - Rotor winding ground fault design
Junki Park
Junki Park Altair Community Member
edited January 2024 in Community Q&A
Hello!
How can i design abnomal conections (ground fault) in the ROTOR winding of a synchronous generator?
I can make circuit of stator ground fault like this.(below pic) but i don't know the case of rotor winding ground fault.
should i just add resistor(1e-6) At the gournd (1) ,  or add another ground(2)  ?
  • C_Favre
    C_Favre
    edited January 2024
    For the rotor winding ground fault do you want to represent short circuits between turns of the winding? In this case the solution is to decrease the number of turns in the rotor to simulate this short circuit.
    I hope this helps.
    Best regards.
    Cyril Favre
  • Junki Park
    edited January 2024
    I hope this helps.
    Best regards.
    Cyril Favre
    No, it does not mean turn to turn fault (short circuit)
    i mean (phase?) to ground fault.
Welcome!
Welcome!
