Help with replace function in hive table
I have a Hive table in which I have some ID that are 10 characters long, but I have some cases in which is 9 characters, one of them is a point and what I need to do to correct it is to delete the point and add a zero in the beginning of the text, (The origin of the ID is nominal) I tried the following function but it says there is a problem with the array_contains, because is not an array, and I dont see any other function that does that, I saw there are some replace functions available but I dont see them displayed in rapidminer studio 8.2.
if(array_contains(cuenta,"."),concat("0",regexp_replace(cuenta,".",""),cuenta))
Please help me if you have any idea
How about using locate?
select if(locate(".", cuenta) == 0, cuenta,concat("0",regexp_replace(cuenta,"\\.",""))) from table;
Cheers,
Máté
