I retrieved the Titanic dataset, than multipied it, and Copy and paste 3x split data operators at a 0.7/0.3 split. The data results are different each time. Now, I can set the local random seed to something in order to make sure it splits exactly the same each time, but I would've expected in this case that it inherits the Global Random Seed by default. Is this expected behavior? It seems unintuitive if it is.
If it is expected behavior, is there an option somewhere to force randomization operators to use a global random seed?
I am using RapidMiner Studio 8.2.
Thank You,
Please see XML below.
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve Titanic" width="90" x="45" y="340">
<parameter key="repository_entry" value="//Samples/data/Titanic"/>
<operator activated="true" class="multiply" compatibility="8.2.000" expanded="true" height="124" name="Multiply" width="90" x="179" y="391"/>
<operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="82" name="Split Data (4)" width="90" x="447" y="595">
<enumeration key="partitions">
<parameter key="ratio" value="0.7"/>
<parameter key="ratio" value="0.3"/>
</enumeration>
<operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="82" name="Split Data (3)" width="90" x="447" y="442">
</enumeration>
<operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="82" name="Split Data (2)" width="90" x="447" y="289">
</enumeration>
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve Titanic (2)" width="90" x="45" y="748">
<operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="82" name="Split Data (5)" width="90" x="313" y="748">
</enumeration>
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve Titanic (3)" width="90" x="45" y="850">
<operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="82" name="Split Data (6)" width="90" x="313" y="850">
</enumeration>
<connect from_op="Retrieve Titanic" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Split Data (2)" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_op="Split Data (3)" to_port="example set"/>
<connect from_op="Multiply" from_port="output 3" to_op="Split Data (4)" to_port="example set"/>
<connect from_op="Split Data (4)" from_port="partition 1" to_port="result 3"/>
<connect from_op="Split Data (3)" from_port="partition 1" to_port="result 2"/>
<connect from_op="Split Data (2)" from_port="partition 1" to_port="result 1"/>
<connect from_op="Retrieve Titanic (2)" from_port="output" to_op="Split Data (5)" to_port="example set"/>
<connect from_op="Split Data (5)" from_port="partition 1" to_port="result 4"/>
<connect from_op="Retrieve Titanic (3)" from_port="output" to_op="Split Data (6)" to_port="example set"/>
<connect from_op="Split Data (6)" from_port="partition 1" to_port="result 5"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
</process>
</process>
