Is there any way to get the number of rows (ExampleSet) from every "Read Database" inside a information value to work with?
I need to know how many rows come from every "Read Database" Query.
Thanks!
Thomas
Hi @thomas_wiedmann,
Here an example of process (to adapt to your own project) to get the number of rows of an exampleset :
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" breakpoints="after" class="retrieve" compatibility="8.1.001" expanded="true" height="68" name="Golf" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="extract_macro" compatibility="8.1.001" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="120"> <parameter key="macro" value="eCount"/> <list key="additional_macros"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="8.1.001" expanded="true" height="82" name="Provide Macro as Log Value" width="90" x="380" y="120"> <parameter key="macro_name" value="eCount"/> </operator> <operator activated="true" class="log" compatibility="8.1.001" expanded="true" height="82" name="Log" width="90" x="514" y="136"> <list key="log"> <parameter key="Direct" value="operator.Extract Macro.value.macro_value"/> <parameter key="Indirect" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_op="Golf" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Does this solution answer to your need ?
Lionel
Hi @lionelderkrikor
yes, "Extract Makro" operator will do the job. I will rebuild my process...
