Hello everyone,
I getting this error whenever i try to use Map clustering on labels on any imported dataset in rapid miner. The model works fine on any in build dataset in rapid miner.
hi @sakib5271 - welcome to the community. What error? I don't see anything in your post.
Some other quick recommendations for you:• Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply)• Attach your dataset if possible (use a fictionalized version if there are privacy concerns)• Make sure you have all dependent extensions installed (see https://youtu.be/pjBqG3xtXx4)
Scott
