I have some problems on the Templates of RapidMiner.
I did the Market Basket analysis available in the Templates of RapidMiner.
I have the picture "capture2" as a result.
How can I make this graph more readable ?
How can I not show the rules on the graph ?
How can I show the results as a tree ?
I also did the Geographical distances template on RapidMiner. I have a map of the closest antennas to every client. The picture "capture3" is my results.
How can I get the clients and the antennas coordonates on the same graph ?
How can I get the clients number fo each antenna location on the graph ?
Can I have the minimum distance between a client and his closest antenna ?
Thank you for your help !!
Selina
